Like the header says... my mobo (ECS K7S6A) has a jumper to set 'CPU Ratio'... what should I set this to for an AMD AthlonXP 2000+? Is there a standard position?
Thanks!
I have the previous model of that mobo, and I can tell you for sure that it's jumperless. Unless ECS has taken a step backwards, I would think it's still jumperless. Just do the auto settings through the BIOS.
On the 5A, you can't actually pick the multipier clock. All you can pick is the bus/CPU frequency. (ie. 133/133, 100/100, 100/133).
Actually...now that I look at it closer... you can do it both ways on the 6A. There IS a jumper BUT it can be either set to the multiplier OR tell it to do it automatically (which I am going to leave it in).
Thanks for your help!
