What should I use to fill speaker stands?
Discussion in 'Archived Threads 2001-2004' started by Mike Improvius, Feb 12, 2003.
  1. Mike Improvius
    Mike Improvius Auditioning
    Dec 30, 2002
    5
    Just curious what the recomendations are. I was thinking either playsand or lead shot.
    Thanks.
    -Mike
  2. Stephen Hopkins
    Stephen Hopkins HW Reviewer
    Jul 19, 2002
    2,598
    Sand, Lead Shot, Marbles, Gravel, anything that's dense and you have readily available.
    One thing to keep in mind w/ sand is the bottom must be completely filled... with the other reccomendations you can always run your cable through the column THEN fill and not have to worry about leaking while still keeping your cables conceiled.
    Hope this helps [​IMG]
  3. Tim Morton
    Tim Morton Stunt Coordinator
    May 5, 2000
    212
    I just bought new speaker stands and did alot of obsessing over just this question. The research led me to believe that a mixture of lead and sand is best. I added a 25lb bag of lead to each of my stands. This filled them about half way each, and then topped off with dry sand. The reason i got for doing this was that the lead, while being very heavy can also cause sound issues with resonances. So the sand on top of the lead is to damp those resonances. Who the heck knows if any of that matters...but i sleep very well at night knowing my resonances are dampened properly.
  4. Chuck Bogie
    Chuck Bogie Second Unit
    Jan 14, 2003
    397
    I shoot competition benchrest, resting the rifle on "sandbags" (hey, yep, that $75 hand-crafted piece of cordura and leather is a "sandbag"). Lots of guys use zircon sandblasting sand because it is heavier than normal silica-type sand. Personally, I'd mix lead shot with el-cheapo sand.
  5. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    would not using lead shot imply that your stands are now an EPA hazard should you ever want to dispose of them?
  6. David Sorenson
    David Sorenson Stunt Coordinator
    Jan 19, 2001
    92
    My local dealer said that a good cheap filler was kitty litter. Haven't tried it.
  7. Aaron Lock
    Aaron Lock Extra
    Dec 27, 2002
    18
