I need some help with what I should use to clean my rp hdtv screen. A friend told me vinegar and distilled water but I want to be sure. Please help. Thanks!
That would scratch the screen would it not? I have a terry cloth but I do not no what solution to use. I have a couple of hand prints from my 1yr old when he decides to try and touch dora or blue. :b
It may sound cheesey but I have found that this stuff works- Monster Cable sells a rear projector (aka Big Screen) cleaning kit. It contains a soft terry cloth like towel and a spray bottle with cleaning solution. I have found that this works very well on my Mitsubish 55".
I use "Plexus" it's a plastic cleaner/polish.I also use a "Micro fiber" cloth. OR just buy two microfiber cloths, one damp clean in horizontal swipes NOT CIRCLES, then wipe with dry microfiber. You can get a microfiber in the automotive dept. of walmart or go to a pep boys, carquest, any car parts store will have them. DO NOT use paper towels, old t shirts or terry cloths as they WILL scratch the screen.
