What should I look for in a light dimmer that will be in my ht room?
Discussion in 'Home Theater Projects' started by james e m, Nov 23, 2003.
  1. james e m
    james e m Second Unit
    Jun 3, 2001
    497
    We are going to put two dimmer switches in our ht room, but I've heard they can cause some problems. So I have some questions:
    What problems do the cause? Hum?
    Do they only cause them when they are on, or all the time?
    Can someone point me in the direction of some ht friendly light dimmers?
    James
  2. GeorgeJM
    GeorgeJM Agent
    Nov 4, 2003
    41
    Yes, hum *may* be an issue, typically only when they're in the dimmer mode. However I have a dimmer switch in the same room as my HT equipment (edit: purchased at HomeDepot, brand unknown) and it doesn't cause any hum.
    I think all you need is good quality connections and hum should not be a problem.
  3. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
  4. Adam Gregorich
    Nov 20, 1999
    15,754
    700
    The Other Washington
    Adam
    I have been using a Lutron Spacer dimmer for several years with no problems. The fact that you can dim the lights from the remote makes it a great choice.
