What should I get $1000-$1500
Discussion in 'Displays' started by Rob Rosenberg, May 27, 2005.
  1. Rob Rosenberg
    Rob Rosenberg Auditioning
    May 26, 2005
    2
    Looking to get a tv. I just moved into a basement studio apartment. But I would like a relatively large sized screen. I was looking into getting a 32" LCD, found a westinghouse for $1400. Is westinghouse anygood? I don't want a bulky 150 pound+ tv. I want hdtv, widescreen. I was totally into getting a lcd, but then I saw some posts about projecters. How are those with Video games? dvd's? and hdtv? How far back must they be? Studio isnt huge, but I want something nice. Thanx in advance for any and all help.
    Rob
  2. Rob Rosenberg
    May 26, 2005
    2
    actually it was $1500 for the westinghouse. model #
    ltv-32w1
    info...
    16:9 widescreen aspect ratio delivers a cinema-style entertainment experience
    3-2 inverse pulldown for accurate reproduction of film-based sources
    1366 x 768 pixel resolution; accepts all major DTV signals, including 1080i, 720p and 480p, plus standard 480i
    Faroudja's DCDi (Directional Correlational Deinterlacing) eliminates jagged edges that appear with progressive-scan displays for a smoother picture
    Wide 170° horizontal and vertical viewing angles make every seat the best in the house
    Picture-in-picture lets you watch one source while you keep your eye on another
    Ultraslim LCD measures less than 3-7/8" deep; comes with table stand or can be mounted on a wall (using an optional mounting kit)
    Component video inputs make it easy to hook up a DVD player and optimize DVD output for stunning picture quality
    Inputs: 2 composite video, 2 component video (Y, Pb, Pr), 1 S-video, 1 PC (RGB), 1 DVI-HDCP, 1 RF
    Outputs: 2 audio, 1 headphone
    2 built-in 5W stereo speakers and SAP/MTS stereo sound
    8 ms response time
    V-Chip parental controls keep children from being exposed to undesirable material
    Other convenient features include closed caption and auto programming
    Product Details
    Warranty Terms - Parts 1 year limited
    Warranty Terms - Labour 1 year limited
    Product Height 25-1/2" (with stand); 23-1/2" (without stand)
    Product Width 31-3/8"
    Product Weight 34 lbs. (with stand); 30 lbs. (without stand)
    Product Length 8" (with stand); 3-7/8" (without stand)
    Screen Size 32"
    Aspect Ratio 16:9
    Display Type LCD
    Digitally Compatible Yes
    Digital Capabilities HD-ready
    Pixels 1366 x 768
    Contrast Ratio 1000:1
    Brightness 550 cd/m²
    Lamp Life Up to 50,000 hours
    Digital Convergence Yes
    Picture-In-Picture Yes
    DVI Input Yes
    S-Video Inputs 1
    Component Video Inputs 2
    Composite Input 2
    RGB Input 1
    Audio Outputs 2
    Watts/Channel 9
    Speakers 2
    RF Antenna Input Yes
    V-Chip Yes
  3. Jim Mcc
    Jim Mcc Producer
    Feb 11, 2004
    3,757
    38
    Oconomowoc, WI.
    Jim
    Rob, projectors are great with all those sources. How far a projector is mounted from the screen is called the throw distance. It depends on the projector and how big of a screen you want. I have a 106" diagonal, 16:9 screen with my Infocus X1 projector and it's great. I use it for all our DVD viewing and occasional HDTV. You can use your wall as the screen, buy one, or make one for less than $40.00. You need to determine if you want DLP or LCD projector, and 4:3 or 16:9. For your needs,I recommend the Infocus 4805(DLP) projector. Check out Projectorcentral.com to read reviews and learn all about projectors.
