What receiver do you recommend for me?
Discussion in 'AV Receivers' started by Norris, Jan 19, 2004.
  1. Norris
    Norris Stunt Coordinator
    Jul 14, 2002
    201
    I'm looking for the following features:
    7.1 (6.1 is acceptable too) audio
    Coax or optical for audio (my current receiver only has 1)
    Good power (nothing humongous though)
    NO multi room capability (I'll never use it)
    DTS (not a deal breaker if it's not there)
    Multiple video inputs, at least 2 components.
    The Denon AVR 2803 fits the criteria, price is $700.
    Please let me know what else is out there that I should be looking at.
    Thanks!
  2. AndrewKC
    AndrewKC Agent
    Jul 23, 2003
    43
    There has been talk on this and other forums about getting the denon 3803 for less than 700 from 6thave. You might want to do a search for it. Also, I've seen the HK 7200 for just over 800, a pretty good deal also. Both are a step up over the 2803.
  3. MarkStash
    MarkStash Stunt Coordinator
    Dec 21, 2003
    51
    You can get the Denon 3803 for under $700 delivered. They've been running a deal at 6ave.com. Search the boards if you're interested, you'll see the details. Lot of folks on here, including me, have gone this route. Good luck!
    Sorry for the repeat, Andrew and I must have been typing at the same time. [​IMG])
