What proper Rumble Filter setting freq w/ 350w amp
Discussion in 'Archived Threads 2001-2004' started by bruin, Mar 15, 2003.
  1. bruin
    bruin Second Unit
    Nov 29, 2002
    264
    I have a 350w amp from Brian with a rumble filter that can be set to high, mid, low damping and 28, 20, 14hz. I currently have a 20-39CS powered by it. I am planning to buy another amp for a DIY sub tuned to 22hz w maybe the 12" Dayton DVC.
    So is it ok to set it to 20Hz and high damping? Or what are your opinions. My listening preference is 50/50 music/movies.
  2. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
    Hi,
    For a 22Hz Fb, the 20Hz/High-damping setting looks best for use as an infrasonic filter.
    How's it working with your SVS, and what setting are you using now?
  3. bruin
    bruin Second Unit
    Nov 29, 2002
    264
    It's working great with the 20-39 CS. I use the 20hz with mid damping setting on the CS. I only have the gain set at 9am and 0db on my receiver. It's a very powerful and versatile amp.
  4. Tom Held
    Tom Held Agent
    Oct 28, 2001
    32
    bruin,
    I'm about to jump on this amp and have a few questions on bypassing the Rythmiks x-over.
    How do you find the Rythmiks x-over interaction with your receivers x-over settings?
  5. bruin
    bruin Second Unit
    Nov 29, 2002
    264
    Tom,
    I don't think I'm much of an expert on your question. Hopefully someone will help you out.
  6. Tom Held
    Tom Held Agent
    Oct 28, 2001
    32
    Thanks for the reply bruin.
    I was just wandering if you had set the Rythmiks x-over to its highest setting to bypass it in favor of using your receivers x-over, and how it sounded.
    The Rythmik not having a x-over bypass/direct-in is the only apprehension I have about choosing it.
    And, do you have any thoughts/opinion's on the OP Amp upgrade Rythmik is offering?
  7. Brian_DR
    Brian_DR Extra
    Mar 19, 2003
    17
    Having an additional xover adds to the flexibility. In the on-line maunal for SE amp, I show how this xover can help you when one likes to set subwoofer volume 6db (or even higher) than the front channel (most of us do that). Essentially what this does is to bring down the frequency response earlier so that when it reachs the actual xover point, the level matches each other.
    Actually, there are 3 reasons why additional xover will help you. The first one has been discussed above. The 2nd reason is that frequency response of front channels most likely has high Q values. That means when it goes down to say 80hz, it tilts up before rolling -off. The impact is the response after HT's high pass filtering will extend a bit lower than what it is specified, which means there will be more overlap in xover region. The additional xover will reduce the overlap.
    The 3rd reason is on the subwoofer response. These days, subs with high inductance are very popular. The result of high inductance is there will be a bump in the frequency response in the 70-100hz range. Again this will add to the overlap in the xover region.
    Brian DR
    Rythmik Audio
  8. Tom Held
    Tom Held Agent
    Oct 28, 2001
    32
    Wow Thanks Brian!
    I actually had read your on-line manual today and your excellent description of phase/x-over interaction and settings. It was very helpful and informative.
    I'll be making my Rythmik purchase first thing tomorrow, but would like an opinion of the OP Amp upgrade.
    I think I would favor the tighter/punchier bass without the TLo72 OP amps, but also don't want to sacrifice its musicality(sp?)
    Thanks again Brian,
  9. Brian_DR
    Brian_DR Extra
    Mar 19, 2003
    17
    People always wonder if OP amps really affect sound. In really they do. People who claim cannot hear difference most likely have problems in the equipment chain so the differences were masked out.
    Anyway, RC4558 (the one in PE and other similar plate amps) has a sound like this. It is clean. But it chops off the
    resonance of instrument. For instant, if there is only single note, on TL072, it sounds like there are resonance after initial attack (all instruments do, I believe people call it overhang). But on RC4558, the resonance is completely (or almost) gone. Only the initial attack is left.
  10. Tom Held
    Tom Held Agent
    Oct 28, 2001
    32
    Thanks again Brian for clearing this all up for me and the great DIY support your offering.
    I'm off to Rythmik Audio![​IMG]
