What projector would work???
Discussion in 'Displays' started by Demetrius, Jun 8, 2004.
  1. Demetrius
    Demetrius Agent
    Feb 22, 2003
    45
    10
    10' wide screen (aurally transparent = slight loss of lumens), dedicated HT with no windows. 17' X 21' room with two risers and three rows of seats - the closest is just under 10' to the screen. I am worried about the cost so don't suggest a $15K unit. I may have to consider it later but not yet [​IMG]
    Thanks for any and all input.
  2. RandyMathis
    RandyMathis Stunt Coordinator
    Jan 19, 2003
    94
    For such a large perforated screen I would recommend a DLP pj because LCDs don't throw out as much light.
    I am not an expert but take a look at these... they are quite popular and the street price is much lower than you think.
    http://www.projectorcentral.com/nec_LT240.htm
