What other subs are similar to Sony SAWM40? (1 Viewer)
Daniel Mc
What are some subs that are equal to or greater in performance compared to the Sony SAWM40, but that I may be able to find used or on special for a price that is similar to the SAWM40 (which is about $160)?
Chris PC
Maybe not quite that cheap, but the least expensive yamaha subwoofer is similar in performance, if not a little better. Look for that subwoofer. Check out the yamaha website to see the smallest subwoofer.
John Garcia
NorCal
The Yamahas will have better performance in a smaller footprint, but of the 3 more common ones (YST-SW105,205,305), only the 305 has the same low end extension.
Ryan Schnacke
The DLS 10 inch sub from Parts Express (part number 300-630) is supposed to be quite a performer for the money. And for only $100 each you could buy 2 and spend only $40 over the Sony. If you're interested then go to the tech talk forum at Parts Express ( Link Removed ) and search for posts on that part number.
Jack Keck
I have the DLS 10 inch sub. I like it, but have never heard a better sub other than in a store. I'd love to see or evenbe involved in a shoot-out of el-cheapo subs.
TheThrillisgone
