What mix for headphones?
Discussion in 'Archived Threads 2001-2004' started by Chris Brown, Aug 16, 2002.
  1. Chris Brown
    Chris Brown Stunt Coordinator
    Aug 14, 2002
    178
    When listening to a movie on headphones, what Mix is usually the best to choose? do you choose a 2 channel mix, or a 5.1+ mix? I'm thinking the 2.0 mix because headphones have only 2 speakers... but I heard somewhere that dolby headphone uses the 5.1 info to re-create the surround sound effect.
    After hearing that i'm totally confused. ugh.
  2. Michael St. Clair
    May 3, 1999
    6,001
    If you are using DH, use the 5.1 track.
    If you are just using regular headphones, use the 2.0 track to avoid poor downmixing. The existence of a separate 2.0 track typically means that they didn't compromise the 5.1 track to optimize it for downmixing.
