What kind of wire should I use for a 45' sub-woofer run?
Discussion in 'Home Theater Projects' started by Erek_S, Jul 10, 2004.
  1. Erek_S
    Erek_S Auditioning
    Jul 9, 2004
    5
    I am wiring my theater's subs, and wanted to know if I can use a 12ga. speaker wire for the long run to the wall jack (inside the walls, and ceiling) or if I need to use a regular shielded sub cable. Is there any differance? I am running two Klipsch sub's, one 15" and one 10". The first run is about 45 feet to the wall plate, and the second is about 28 feet. I want to make sure that I dont lose too much from the wire, once its in I'm unabe to change it. (not going to rip it apart!!!).
    Thanks Troy
  2. Wayne Ernst
    Wayne Ernst Cinematographer
    Feb 24, 2002
    2,588
    I'm using 12 gauge speaker wiring for a similar run for my sub. I purchased the in-wall wiring for this purpose and it is well-insulated.
  3. Wayne A. Pflughaupt
    Aug 5, 1999
    6,123
    40
    6,610
    Katy, TX
    Wayne
    If the signal you’re sending to the sub is line-level, then you want a shielded cable, not speaker cable. The most economical way to do this is to use regular coaxial cable, RG-6 or –59, like they use for TV antennas. Radio Shack sells screw-on connectors that will convert the ends to RCA.
    Wayne A. Pflughaupt
  4. Wayne Ernst
    Feb 24, 2002
    2,588
    I guess I should have clarified my reponse a bit better. My run is not a line level run, but, rather, a speaker level run between my pro audio amp and my sub cabinet.
    Wayne, from experience, I'll have to completely agree with you. Not having a properly insulated/shielded cable for such a run could be disasterous.
  5. NickSo
    NickSo Producer
    Jul 2, 2000
    4,260
    Nick So
    However, for speaker level runs, the amount of power going through the run will not be affected my interference much, so regular speaker wire should do fine.
    Only with low-level connections like line-level connections is interference an issue, thus shielding.
  6. Yi Yin
    Yi Yin Extra
    Jun 12, 2004
    16
    For the best quality, i suggest Canare LV-61S (RG59) / LV-77S (RG6) with Canare RCAP connectors. However they are relatively expensive and may be an overkill depend on your quality preference.
    Yi Yin
  7. RodN
    RodN Stunt Coordinator
    May 9, 2004
    58
    Although it's speaker level I'd use quad shield RG6 for a run that long, just to be sure.
  8. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    You can easily get away with 12 or 14 gauge for a sub run, after all, what are you passing...frequencies below 120 Hz or so. Since you're running in wall, you should pick up the stuff that's rated CL2/3 to meet any building code. To quickly determine it's suitability buy yourself a 50 foot run (might be cheaper that way...maybe not) and just do a quick hook up. And how does it sound?
  9. NickSo
    NickSo Producer
    Jul 2, 2000
    4,260
    Nick So
    Just curious about the two members who posted after me (and before Chu)...
    How do you manage to use RG59/RG6 coax for a speaker-level run? I've never heard of this method.
  10. RodN
    May 9, 2004
    58
    Just strip it back and away you go (strip the shielding at the same level as the insulation. I had tried running the shielding to amplifier ground but found that made no difference, the shielding was acting as an EMF buffer anyway.
    Solid core vs stranded is an argument for another thread I would suggest [​IMG]
  11. Cornelius
    Cornelius Stunt Coordinator
    Feb 24, 2004
    117
    You'd rather run 18-gauge shielded cable rather than 12-gauge? How would you ground the shielding so that it would make a difference?
    In my experience, 12-gauge speaker wire can be run several hundred feet without a problem.
    CJ
  12. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    Well Erek, let us know what you did and how it worked out.
  13. Erek_S
    Erek_S Auditioning
    Jul 9, 2004
    5
    In further investigations, I found that line-level runs, (not powered) are subject to noise, and interference that is amplified by the sub amp. I was worried about size, I had thought that the bigger the better, which is the case in speaker-level runs (amplified), but not in line-level.
    I went with RG-6 and used the adapter to RCA. It will be a while before I am able to test it, but I'm sure it will be some kicking base.
    Thanks Pflughaupt, and everyone else for their input.
  14. Erek_S
    Erek_S Auditioning
    Jul 9, 2004
    5
    If anyone is interested, i have found using crimp-connectors on RG-6 or 59 has a fairly large loss per fitting. I use the compression fittings, and there is very little or no loss. Unfortunately there is a special tool (about $85 to $140) that is needed, and the fittings are only at a couple places, other than on line, and are ($.45 to 1.50 ea.) The difference is fairly huge, and very much worth it.
  15. Cornelius
    Feb 24, 2004
    117
    Sorry, RodN, I saw the above-response and didn't pay enough attention to realize that it wasn't the original poster clarifying his position. Your response is the correct one for line-level signals.
    CJ
  16. Cornelius
    Feb 24, 2004
    117
    Erek_S, how are you measuring the dB losses? What kind of crimp and compression fittings are you using?
    CJ
  17. Erek_S
    Erek_S Auditioning
    Jul 9, 2004
    5
    I dont remember the name of the scope, had a friend on mine that I installed digital sat. for and he had the scope, and it was at that point that I switched to the compression fittings.
    The tool, and the fittings are digicon. The number on the Tool is #LCCT-1, and the fittings #DS6Q-06-02 There is a phone # on the tool 1-88-TeleWire. I'm not sure if its good, I got this tool last summer. There are others that make the same thing, dont know if this is better or worse? they also sell a cutter, that doesnt have any numbers on it, but it has two razers, and it rotates around the cable, and when you slide it off, the cable has a perfect cut, ready for the connecters.
  18. Cornelius
    Feb 24, 2004
    117
    Thanks Erek. I'm using Canare crimp fittings for all my audio and video cables and T&B compression fittings for my RF connections. This makes me want to go back and test all my connections!
    CJ
  19. Steve_Wingman
    Jan 8, 2003
    46
    Do what I did:
    RG6 Copper Coax cable & gold plated RCA's from rad shack,
    solder the core & crimp the shield-Done!
    -Steve
  20. Wayne A. Pflughaupt
    Aug 5, 1999
    6,123
    40
    6,610
    Katy, TX
    Wayne
    Interesting. I’ve done that with RG-59, but I didn’t know Radio Shack’s RCA’s had entry holes large enough for RG-6.
    Wayne A. Pflughaupt
