what kind of speakers for 6.1 & 7.1 surround
Discussion in 'Speakers' started by chris_bester, May 24, 2005.
  1. chris_bester
    chris_bester Agent
    Apr 24, 2005
    39
    Is it better to go all bookshelves for the surround channels or di-pole or a mixture of both????
  2. Victor Ferguson
    Victor Ferguson Stunt Coordinator
    May 2, 2005
    120
    For 6.1 or 7.1 I would recommend direct radiating all the way around.
  3. chris_bester
    chris_bester Agent
    Apr 24, 2005
    39
    so victor your basically saying bookshelve type speakers all the way around?
  4. Victor Ferguson
    May 2, 2005
    120
    That is correct. If you are going the bookshelf style speaker route you'll probably need to figure in the cost of a sub as well. HSU and SVS both make some really good affordable subs. Speaker stands will probably need to be considered as well.
  5. chris_bester
    chris_bester Agent
    Apr 24, 2005
    39
    all the surround speakers will be wall mounted
    I am going to go Paradigm Studio line all around
  6. Jeremiah Dant
    May 5, 2005
    32
    floor standers do even better if you have the space all around.
  7. chris_bester
    chris_bester Agent
    Apr 24, 2005
    39
    I dont have the room for towers all around so I am going bookselves or di-poles for all surround channels.
