what kind of screen for this situation
Discussion in 'Displays' started by AdamP, Aug 4, 2004.
  1. AdamP
    AdamP Auditioning
    Feb 12, 2003
    10
    I have a perfect place for a screen to use a new projector, but I don't know what kind to get. The problem is that the room has a 10' ceiling. If I hang a pull-down screen the thing will be pretty high for viewing. I can't put up a static screen because there's a fireplace there. WHat do you think I should do? ANyone have or liek the tripod-based screens?
  2. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Let's ask this sort of question here in Display Devices, Adam. You'll get a better response, and, anyway, the Basics area is for general discussion at the beginner level. Thanks, and good luck finding a suitable screen.
  3. Scott Dautel
    Scott Dautel Second Unit
    Oct 6, 1998
    471
    When you custom order a screen from any of the major mfrs., you can customize screen material, size, aspect ratio, and "header length". The latter is where you will need to speciy a longer header. You can order whatever you need to position the screen top edge the proper distance from the ceiling.
    I recently spoke to Dalite about just such a custom order and was surprised to learn that I can get a basic 92" diagonal, 16:9 screen, matte white for ~$350.- (ceiling mount, manual pull-down)
    You can actually order many such custom screens through www.avsforum.com
    Check out their screens forum here
    Scott
  4. Leo Kerr
    Leo Kerr Screenwriter
    May 10, 1999
    1,698
    oh, who was it?
    One of the screen manufacturers - Stewart or the other one - not Dalite - Draper! - makes a chain-hung screen... hang the screen as high as you can. When you press the button to deploy the screen, the whole roller mechanism crawls down the chains, extending them as they go, and then unrolls the screen...
    Overkill, perhaps?
    Sounds cool, though.
    Leo Kerr
