What kind of max screen size is realistic with a CTR Proj.?
Discussion in 'Archived Threads 2001-2004' started by Luke_Y, Dec 27, 2002.
  1. Luke_Y
    Luke_Y Second Unit
    Aug 20, 2001
    424
    Assuming say; an 8" CRT Proj. such as a Ehome Marquee 8000/8500 in a completely light controlled room. As the screen gets larger light output becomes the problem. So what do you think the max diagonal screen size is on a 16:9 screen before you have to drive the Proj. so hard that "Blooming" becomes an issue?
  2. Jim Ferguson
    Jim Ferguson Stunt Coordinator
    Sep 9, 1998
    83
    I have an 8" Barco CRT projector with a 110" diagonal 16x9 screen. I certainly wouldn't go any larger, but it seems to handle this size OK.
  3. Bill Lucas
    Bill Lucas Supporting Actor
    Mar 20, 1999
    530
    Luke,
    I've seen Jim's setup and it looks wonderful (although there may be a different video processor in his system now). I agree that you shouldn't go larger. 96" X 54" is IMPO, about the limit.
    BTW, blooming is not the issue at hand. The problem with overdriving a CRT is that you will burn the phosphors on the face on the used portion of the CRT. Proper light output, greyscale and color purity will be lost as a result. Regards.
  4. Luke_Y
    Luke_Y Second Unit
    Aug 20, 2001
    424
    So do you think it would be fairly safe to say that a 120 inch diag 16:9 screen would be pushing an 8 in CRT too hard or that there just wouldn't be enough light output?
  5. Bill.P
    Bill.P Extra
    Dec 19, 2002
    24
    I've consulted the experts, and the word in about 16 to 20' diagonal should be fine. Of course screen type/gain would come into play here also.
    -Bill
    [experts= my dad who works on Electrohomes/Barcos/etc.]
  6. Sean M
    Sean M Stunt Coordinator
    Feb 12, 2000
    182
    You could do a 120" diagonal 16x9 screen without driving the CRT's too hard if you use a screen with a gain of about 1.8 and are happy with only 9 foot lamberts of light output (commercial theaters have about 12 with film running in the gate). Going for 12 ftL or using a screen with lesser gain at that size would be pushing it. It won't look as good as it would on a smaller screen, particularly the brightness, but it would work.
  7. Luke_Y
    Luke_Y Second Unit
    Aug 20, 2001
    424
  8. Parker Clack
    Jun 30, 1997
    12,216
    59
    9,110
    Kansas City, MO
    Parker
    Luke:
    I projected a Zenith FPTV with 7 inch CRTs on to a 120 inch diagonal flat white painted wall for over 3 years with no problem. I did have it set up in a totally dark room though. Light control is a must with any CRT projector.
    I would think that you would do fine with a 120 inch screen with the Ehome projector that you have in mind.
    Parker
