Steve Elias
- Jan 1, 2002
I have purchased a Rotel RSP-976 pre/pro and a Rotel RMB985 Mk II amp, and I need cables to connect them. I initially planned on purchasing some stereo audio cable to make the five connections between the two units, but doubts crept in after I read through too many threads. The cables connecting the pre/pro to the amp are for the sole purpose of transmitting the audio to the speakers (unless I'm missing something?) so my initial plan is the correct plan, is it not? If not, then what kind of interconnects should I use? Digital? Video, so as to have 75 ohms instead of 50 ohms?
I was considering these:
http://www.araccessories.com/pro2/pr..._id=2&sub_id=7
Also, if I have a problem finding a single cable for the center channel connection, can I simply purchase another pair of stereo audio cables and just use either one of them for the center channel? I assume the red and white markings are simply to make it easier to make the proper connections between amp and speaker.
I suspect I'm too tired and I've been thinking too long about what should be a simple matter...
Thanks for saving my sanity.
-Steve
-Steve
