What just hapenned to my sub?
Discussion in 'Home Theater Projects' started by Brett Creider, Oct 28, 2003.
  1. Brett Creider
    Brett Creider Stunt Coordinator
    Oct 7, 2003
    75
    I was listening to that "I like big speakers" song...moderate volumes...up close watching the sub...
    It's doing fine not bottoming or anything then suddenly it just dies. Amp is still on, no sound out of sub...
    .....did I just kill it?
  2. Darren_T
    Darren_T Second Unit
    Oct 1, 2001
    494
    Amp got too hot. Let it cool down and see if it starts up again.
  3. Brett Creider
    Oct 7, 2003
    75
    You're right...I just felt back there and it's pretty hot...any way to cool it down more while it's running so it doesn't cut off more often?
  4. Darren_T
    Oct 1, 2001
    494
  5. Brett Creider
    Oct 7, 2003
    75
    It is the Parts Express 250watt remote control amp with a Tempest...
    It's sealed and there's 60oz of polyfill in the box too.
  6. Darren_T
    Oct 1, 2001
    494
    I have the same amp. I had this happen once also when I was running successive 20hz tones. Basically, if you must have the sub calibrated too "hot" you'll have to mount a small fan or calibrate your sub to "proper" levels. I know, "proper" levels don't give you the bass impact you desire. I had to adjust my expectations also. You'll find the music to be much more balanced though [​IMG] Home theater will still have tons of impact but music will be more natural.
  7. Brett Creider
    Oct 7, 2003
    75
    It is used mostly for music....like 90% of the time....I was just wanting to see what she'd do [​IMG]
  8. Brett Creider
    Oct 7, 2003
    75
    It did it again [​IMG] lol I'll just put a fan back there somehow...
  9. Darren_T
    Oct 1, 2001
    494
    You'll be fine then. You gotta test the limits or it will always be in the back of your head... I did the same thing with my sub. Just be glad the amp had protection circuitry.
  10. Darren_T
    Oct 1, 2001
    494
  11. PaulDF
    PaulDF Second Unit
    May 17, 2002
    354
    Brett, I went through this exact same scenario after I completed my Tempest sub. I'd crank up the bass to feel the house shake, and my amp would get quite hot. I just set a fan in front of my separate plate amp box, and all was well, when I needed to really crank on the bass.
    And, just as Darren says, I eventually learned to turn the bass down. Music does sound a lot better when its not dominated by the subwoofer. Mine is by no means at calibration levels for music, as it is still 8-10 db hot. Its tending to go down, as time goes on and the novelty wears off.
    Since my box is an EBS, I chose to add a parametric equalizer to tune the bass to my liking, for music. This works very well for me.
  12. Brett Creider
    Oct 7, 2003
    75
    Another question off topic while I let it cool down...
    Why does car audio sound like crap? My neighbor and all the friends I know with subs all have car audio, not home. I've listened to them and sure they get loud and they rattle everything but they have no definition at all. They are very boomy and not at all tight, but they think it sounds great. I played the same song on my system in here and in their car and it seems they go louder but it's just boom all the time....
  13. Brett Creider
    Oct 7, 2003
    75
    Paul...
    That sounds about right lol. I've been building it for 5 days and I was researching it for a month...and nearly $400 was spent on it....
    So I've got some high hopes for this thing I guess...
  14. Darren_T
    Oct 1, 2001
    494
  15. Brett Creider
    Oct 7, 2003
    75
    lol well I am a "kid" I guess, just turned 18 last Thursday but my friends all want stuff that hits hard. That's all they want. They have decent head units and some of them have decent speakers but they all want boom.
    I want clean, tight sound not just something to set off car alarms...
    Ya I was born 10/23/85 so when you had those 2 10s...I was born lol...
  16. Darren_T
    Oct 1, 2001
    494
  17. Kyle Richardson
    Kyle Richardson Screenwriter
    Jan 1, 1998
    1,073
    Wanna hear somthing that sounds great and still gets loud? Try that same Tempest in a car with 500 watts [​IMG]
    Yes, I'm probably Darrens age but I like it loud and CLEAN!
  18. Juan Castillo
    Juan Castillo Second Unit
    Jan 22, 2002
    434
    Brett, you are just more mature and enlightened than your friends.. Most kids grow out of the boom phase and want quality later on, after they have grown partially deaf, and pissed off all their neighbors and total strangers.
    You are just past that stage without ever having been there. I'm the same... or should I say, I was the same as you.. Hell, teach your friends, that you can have a system hit hard, and with a different eq setting, you can have quality sound too.. good luck though..
  19. Ronnie Ferrell
    Ronnie Ferrell Second Unit
    Jul 16, 2002
    355
  20. Darren_T
    Oct 1, 2001
    494
    Hi Ronnie,
    Nope, it wasn't that early of a model [​IMG] It was an in-dash CD player...it wasn't one of the first CD players but was the first in my group of friends [​IMG]
    Are ya finished with that gorgeous Tempest yet? I wanna see the finished product.
