What is the weak link in my setup?
Discussion in 'Archived Threads 2001-2004' started by Boka, Jul 29, 2002.
  1. Boka
    Boka Stunt Coordinator
    Jul 29, 2002
    61
    Current setup is:
    JBL S-310's (main)
    JBL S-Center II
    JBL S-36 II's (surround)
    Pioneer VSX-D508 100W x 5 receiver
    What do you think the weakest link is ?
    Best upgrade for $300 or so ?
    I'm already looking at adding a sub so leave that out.
  2. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    By far the receiver. But you'd have to spend more than $300 to make a large improvement. Although the Pioneer 810 can be had around $300 now a days I believe and it would be a reasonable step up. There are also a few Denon, Onkyo, Harman Kardon and Yamaha receivers in the price range you could consider that would be a step up.
  3. Geoff S
    Geoff S Stunt Coordinator
    Jun 1, 2002
    239
    You could get a nice two channel amp to drive your main speakers, and leave the receiver some headroom to drive the rest.
    You can still keep the amp and use it on other receivers, or pre/pros long after that Pioneer is gone.
  4. DanaA
    DanaA Screenwriter
    Nov 21, 2001
    1,843
    I agree with Geoff that a nice two channel amp would be a nice improvement, assuming you have preouts on your receiver. For instance, on Ubid.com today, an Audio Source 80 watts/channel amp is at $109. I, however, don't have any personal experience with Audio Source, but believe I've heard some positive comments on HTF.
  5. Stephen Hopkins
    Stephen Hopkins HW Reviewer
    Jul 19, 2002
    2,598
    The 811S can be had for as low as $280 + shipping on yahoo shopping. the 711 can be had for even less. either would be a step up, and the 811S would give the equipment to move on up to 6.1 or 7.1 when you want to.
  6. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    Oops, I meant 811. The 508 does not have preouts for anything but the sub. So a seperate amp isn't an option.
  7. Geoff S
    Jun 1, 2002
    239
    Then since a separate amp isn't possible with that old Pioneer, then by far I agree the weakest link is that, and you should upgrade it before anything else.
    If you can save up a little more than $300 (say $400-$600) a toally decent 6.1 receiver can be had.
  8. Boka
    Jul 29, 2002
    61
    thanks for all the ideas.
    Assuming I had 400 or 500 tops (funny how it always goes up) to blow, what receiver would be my best bet. I'm interested in quality more than loudness, 95% of the time it would be used for movies, don't care too much about video switching, etc...
