What is the Proper Backlight?
Discussion in 'Archived Threads 2001-2004' started by Bob Sison, Nov 26, 2001.
  1. Bob Sison
    Bob Sison Extra
    Nov 20, 2001
    17
    I was told to put a source of light behind the TV to improve the image. The description came in terms of temperature (e.g. 6500 degress). In lay man's terms, what kind of light is this? Fluorescent? Incandescent?
  2. Bob D
    Bob D Extra
    Jan 26, 2001
    22
    Bob,
    Just do a search on Bias Light and you will find more info than you can digest! Good Luck.[​IMG]
  3. errol
    errol Stunt Coordinator
    Dec 29, 1999
    150
    Hi Bob,
    Most find and use the flourescent type which are not easy to find. More info here.
    Errol
  4. Bob Sison
    Bob Sison Extra
    Nov 20, 2001
    17
    Thanks guys.[​IMG]
  5. Paul Hives
    Paul Hives Auditioning
    Oct 12, 2000
    8
    I found the flourescent at a PETSMART. They are very popular with aquariums. The pacaking will indeed say 6550K.
    Any fixture for an 18" bulb will do the trick. I just velcro'd mine to the back of the set. Let it shine on the wall.
  6. Eric B
    Eric B Auditioning
    Apr 16, 2000
    2
    I was able to find a 6500K flourescent bulb at Home Depot that screws into a standard lamp socket recently. Its labeled Daylight and works well. I put it in a small 'can' light fixture. I think it was $6.99.
  7. Paul Hives
    Oct 12, 2000
    8
    The probelm that I found with so called "daylight" bulbs is that they are not 6500k. We actually took measurements with the analyzaer.
  8. Eric B
    Eric B Auditioning
    Apr 16, 2000
    2
    The one I purchased said 6500K on the box and bulb. I also have seen many 'daylight' bulbs that were not 6500K.
    This was the first one I have seen that is clearly marked as such.
  9. PS Nystrom
    PS Nystrom Second Unit
    Jan 27, 1999
    444
    Ah, very helpful. Thanks for asking and answering the question I was about to ask.
    Pieter
  10. Scott L
    Scott L Producer
    Feb 29, 2000
    4,457
    Home Depot sells the Philips Daylight, namely the F20T12/D. Only problem is that it's only 74 CRI (90+ is recommended) and I couldn't find it any shorter than 24". I use this for a 32" wega and if you sit on the side couch you can see the back light. Try getting an 18"er if you have less than a 36" set and have side seating.
  11. Jeff Kleist
    Dec 4, 1999
    11,267
    Might I suggest turning out the lights and watching in the dark? I find the backlights distracting in the extreme.
  12. MichaelGomez
    MichaelGomez Stunt Coordinator
    Oct 4, 2001
    134
    Scott L
    Middle row far left?
