What is the OAR of Christopher Nolan's FOLLOWING? (1 Viewer)
Kelly W
I just picked up the DVD of Following at Fry's and noticed that it says "Fullscreen Presentation". I looked at the discs and didn't see any inidcation that there were two separate releases of the film (i.e., widescreen and fullscreen).
Amazon.com says that the disc contains the film in an anamorphic widescreen format, but they've been wrong before.
The Internet Movie Database doesn't list the "Technical Details" for the film so I can't check what the OAR is.
Does anybody know if the OAR of Following is 1.33:1?
Thanks!!!
-Kelly
Kelly W
Okay, I'm going to answer my own question here...
After looking at several reviews of the disc on the web, it appears that the OAR IS 1.33:1 and that is the only version of the film available.
Whew... I'm glad that's covered. :)
-Kelly
Bjorn Olav Nyberg
To expand a little bit, if you have the US version of the Memento DVD, they talk about Following on the documentary as well, and Nolan does say it was shot in academy, which means 1.33:1 (or 1.37:1 to be precise)
CrossAtlantic
