What is the largest screen size recommended to use with a 9" CRT projector and DVD?
Discussion in 'Archived Threads 2001-2004' started by Ricardo C, Mar 21, 2002.
  1. Ricardo C
    Ricardo C Producer
    Feb 14, 2002
    5,059
    What is the largest possible screen width one could reasonably go for before the image started showing its flaws? I know this is a subjective question, but I figured the hard-core videophiles, who really care about image quality, might give me the best answer [​IMG]
  2. Paul Jenkins
    Paul Jenkins Supporting Actor
    Jan 4, 2000
    965
    It depends on your screen type really. With a Torus screen properly built, you can achieve remarkable gain allowing your screen to be very large.
    For a good tutorial/reference site, goHERE
    Once you read that, post some more questions.
  3. Chris Purvis
    Chris Purvis Stunt Coordinator
    Dec 11, 2001
    151
    Further, with a 9" CRT it's not 'flaws' that will stop you increasing the size but brightness. Even with a torus screen you can only go so big with a single projector before the image begins to get too dim.
    Of course, you could always buy one of these:
    http://www.barco.com/projection_syst...sp?element=886
    It would probably go as big as you'd ever want, but...[​IMG]
  4. Ricardo C
    Ricardo C Producer
    Feb 14, 2002
    5,059
    ...But I'd probably have to sell all of my internal organs to afford it? [​IMG]
    Thanks for the tips/links, guys [​IMG]
