what is the diff. between EDTV and HDTV?
Discussion in 'Displays' started by paul watkins, Feb 20, 2003.
  1. paul watkins
    paul watkins Stunt Coordinator
    Feb 22, 2002
    84
    Daewoo 42" Widescreen Plasma EDTV Display Panel
    Model: DP-42SM
    is this tv a HDTV?
    PRODUCT FEATURES
    42" 16:9 plasma display panel with 480p native resolution (853 x 480 pixels) — accepts inputs in all major DTV formats (1080i, 720p, 480p and 480i), plus PC video
    Less than 3-1/4" deep — comes with table stand, or can be mounted on a wall (using an optional mounting kit)
    Wide viewing angles: 160 degrees (horizontal and vertical)
    Extremely high brightness (600 cd/m²) and contrast ratio (3000:1), with 5 selectable picture modes for excellent performance in a wide variety of lighting conditions
    3D digital comb filter enhances color purity of A/V and S-video input sources, reducing cross-color artifacts like dot crawl and moiré
    RS-232C serial port for future software upgrades and fast service diagnostics
    PC input (15-pin D-Sub), 2 component video inputs (1 wideband), 1 S-video input and 1 composite A/V input; 5 stereo audio inputs
    Picture-in-picture capability (PC on video)
    Dynamic Pixel Management system protects against screen burn-in by orbiting pixels within an assigned grid when an image remains static for too long
    Open air flow design ensures long plasma-cell life, and permits quiet operation with no cooling fan
    Built-in 16-watt hi-fi stereo audio system with flexible 5-band EQ, simulated surround and balance controls — can feed optional, matching 3-way Daewoo tower speakers or other external stereo speaker system (does not include built-in speakers)
    Includes simplified standard remote for intuitive operation
  2. paul watkins
    Feb 22, 2002
    84
    will it play an HD signal
  3. Gilbert ^P
    Gilbert ^P Stunt Coordinator
    Nov 5, 2002
    58
    only 480p which is not hdtv
  4. BrianDB
    BrianDB Agent
    Feb 16, 2003
    43
    I do believe that it will accept those signals. If they say it is an EDTV it will only display 480p. It most likely down-converts the signals for display.
  5. BrianDB
    BrianDB Agent
    Feb 16, 2003
    43
    Info from the net.
    http://www.reviewboard.com/Section/Cover/DP-42SM
    Here is a snippet.
    Screen size: 42" wide screen (Aspect 16:9, Normal, Panorama, Full Screen)
    Contrast ration: 3000:1
    Brightness: 600 cd/m2
    Resolution: 852 x 480 (EDTV 480P)
    20 step Zoom, Picture Freeze
    Four Pre-Set Picture modes for room brightness, Normal Cinema, Dynamic, User
    Depth & Weight: 3.15 " Depth, 66 lbs.
    160 Degree Viewing Angle (Both Horizontal & Vertical)
    NTSC/PAL/ SECAM format playback (Free Volt 100-240V 50/60Hz)
    Accepts 1080I, 720P, 480P, 480i signals
  6. Scott L
    Scott L Producer
    Feb 29, 2000
    4,457
    Any plasma that hovers aound $3k is only 480p, therefore not HDTV. They can usually accept an HD 720p/1080i signal but it will be downconverted to 480 lines of resolution. You get what you pay for with plasmas, why not grab a Sanyo Z2? [​IMG]
  7. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
  8. Jeff W.
    Jeff W. Stunt Coordinator
    Dec 21, 2003
    141
    "Normal" TV is 480 lines, interlaced, or 480i. This is sometimes now called "Standard Definition" or "SD".
    "Enhanced Definition" or "ED" is also 480 lines, but it's non-interlaced aka progressive scan, or 480p. This is what is stored on DVD. I'm sure that set would look great with DVDs, but...
    "HIGH Definition" or "HD/HDTV" is either 720 lines progressive (720p) or 1080 lines interlaced (1080i). Trying to show a picture with 1080 lines on a set with only 480 lines resolution.. well you can do the math.
    SD = 480i (good ol' TV)
    ED = 480p (DVDs and some broadcast TV stations)
    HD = 720p and 1080i
    Btw that Sanyo Z2 only has 720 lines. Personally for $3k I'd get a RPTV (CRT) and spend the extra cash on a couple dozen DVD discs, beer and popcorn... [​IMG]
  9. i think most people should actually view a tv with 480p native resolution displaying an hd signal. it's actually really good still. my brother has a rptv panasonic and his picture does not look as good as my plasma spn4235 samsung edtv plasma. i dont think hd is all that neccessary on plasma. atleast in the smaller sizes like 42"
    also, the daewoo plasma is pretty sucky. i suggest an akai from costco if your limited to cash flow. it's a better alternative.
  10. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    FYI: DVD is only 480i.
