What is the correct way to install bucking cancellation magnets to add shielding to s (1 Viewer)
Reginald Trent
I guessing they should be installed as to push against each other as oppsoed to sticking together. So which way is correct?
Reginald Trent
Does the bucking magnet have to be perfectly centered against the existing magnet for best/maximum results?
Patrick Sun
They should be "balanced/centered" so the stray magnetic fields are "bucked" the same in all directions.
maltby
