What is the Break-in period??
Discussion in 'Archived Threads 2001-2004' started by Calvin_Su, Nov 1, 2002.
  1. Calvin_Su
    Calvin_Su Stunt Coordinator
    Jan 18, 2000
    186
    I hear that TVs shouldn't be calibrated until the break in period, which is 100 hours.
    What exactly is this, and does it mean 100 actual viewing hours, or just 100 hours after the set is plugged in?
  2. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    It's hours-of-use. When you turn it on, things heat up which can affect the electronics and alignment. The electronics usually steady out in about 30 minutes, but over the first 100 hours the alignnment will become more and more consistant one time to the next.
    So turn down the sharpness & brightness with the user-controls and enjoy for about a month or two before paying a tech to do a professional calibration.
  3. Calvin_Su
    Jan 18, 2000
    186
    Thanks.
    Does the picture quality improve in this period?
  4. Jon Alan
    Jon Alan Auditioning
    Oct 28, 2002
    9
    Bob - don't you mean turn down the "contrast" and brightness? Although, sharpness is usually set too high out of the box as well.
  5. Levesque
    Levesque Supporting Actor
    Mar 21, 2002
    586
    From what I uderstand, and what I did, it's better to do short periods of 4 hours on, and 30 minutes off to let the set cool down. For my 65HDX82, the PQ did improve a lot. I was skeptical at first, but after 300 hours, SD-brodcast and DVD are better, less grainy, and simply "better".
    If you are considering ISF calibration, then you should aim for a 200-300 hours. Just to be sure nothing goes wrong, and paying for nothing for this calibration. Usually, a period of 2 to 3 months is a safe bet. My ISF calibrator did actually refuse to do the calibration before 2 months of break-in.
  6. Bob McElfresh
    May 22, 1999
    5,182
  7. BruceSpielbauer
    BruceSpielbauer Second Unit
    May 27, 2002
    275
    RE: Turning down the contrast
    >>>Perhaps... most TV's have their settings turned too high so if the unit is picked to be a demo unit on a sales-floor, it will stand out. Contrast is another setting that is set too high to help the display look sharp to a potential buyer.
