What is the best way to clean an RPTV screen?
Discussion in 'Displays' started by Matthew Brown, Jan 26, 2004.
  1. Matthew Brown
    Matthew Brown Supporting Actor
    Sep 19, 1999
    781
    I need to clean the screen of my Panasonic 47WX49 RPTV and was wondering what is best to use.
    I had some work done a while back on it and the technician installed a free protective screen. I recently noticed dirt in between the protective screen and the regular ones.
    I had already taken it apart and cleaned it once using a soft cloth but I noticed more dirt after closing it back up.
    Is there anything that is made for this type of screen? I don't want to scratch it but the clothe didn't seem to do the job.
    Any help would be greatly appreciated.
  2. Sean Moon
    Sean Moon Cinematographer
    Jan 25, 2001
    2,041
    I am in a similar situation with the same model TV. I talked to a local HiFi shop, and the person said just a damp cloth would work, but be gentle. And he offered the suggestion of a softhead toothbrush lightly on hte screen to get in the grooves. I still am scared to do anything to this screen.
  3. JoeRiley
    JoeRiley Stunt Coordinator
    Jan 9, 2003
    82
    Best Buy sells a little kit for RPTV cleaning... should be right out back in the home-theater/big tv section.
    I think it's by Monster... and it runs $20.
  4. Matthew Brown
    Sep 19, 1999
    781
    Thanks for the suggestions! I appreciate it.
    Matt
  5. JoshuaT
    JoshuaT Stunt Coordinator
    Sep 20, 2003
    61
    The kit that BB sells is a microfiber, the one from Monster. It is very good as I have been using it for about two years. The static free spray won't help you too much in your situation but is really good as well. Always use a microfiber!! Don't break out your I don't care how soft it is dish towel!!! Use microfiber!
    ~josh
