What is the best solution?
Discussion in 'Displays' started by Justin_D, Feb 15, 2004.
  1. Justin_D
    Justin_D Stunt Coordinator
    Dec 27, 2003
    217
    I like to watch ALOT of TV
    When nothing is on, I like to watch a movie, usually once a day, sometimes more on weekends.
    I also listen to alot of music, but that is beside the point.
    My question is this:
    Would a projector meet my needs? I konw the bulbs and stuff burn out, needing replacement. But I want to know if I should be looking at projectors or stick with the other beastly displays.
  2. Justin_D
    Dec 27, 2003
    217
    Oh...no one wants to play with me...
  3. Mark Romero
    Mark Romero Second Unit
    Sep 11, 2000
    391
    What do you currently have?
  4. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    I'd get a projector if you have the room for it (light controlled). Regardless, if you get something like an CRT-RPTV, tubes wear just the same as a CRT FP setup, and if you get a digital pj RPTV, you get the same bulb replacement costs as a FP. Either way, if you have the dark room, you're looking at similar costs, why not go for a bigger picture?
