What is the best product to use to seal drivers.
Discussion in 'Archived Threads 2001-2004' started by Ken Lopata, May 22, 2001.
  1. Ken Lopata
    Ken Lopata Agent
    Feb 7, 1999
    42
    What's the best product to seal airtight drivers and p.r.'s. Is there a precut 15" gasket thay will work with the HE15 driver and Lambda 15" p.r.'s, or do you not use anything and just screw the drivers down tight. Thanks
    Ken
  2. Julian Data
    Julian Data Second Unit
    Oct 5, 1999
    408
    Hmm.. Audiomobile provides a silicon gasket with their drivers.
    What I have been using is the weatherstrip foam tape I just adhere to the enclosure so I can just pull the driver(s) on and off.
    I have tried Mortite, great stuff, but messy and a PITA to get off the driver, hence the move to the foam tape. There's also the sealing caulk that PE sells. Pretty messy too. But they all work.
    I hope this helps.
  3. Ken Cline
    Ken Cline Stunt Coordinator
    Jun 30, 1997
    99
  4. Patrick Sun
    Patrick Sun Studio Mogul
    Jun 30, 1999
    38,761
    485
    9,110
  5. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    Coincidence? I bought some 3/8" weatherstripping yesterday for this purpose.
    Patrick - Do you stick the w.s to the enclosure and leave the tape backing on the front side so the driver won't stick to it? What if you want to remove the driver in the future and both sides of the w.s. glue are used. You would have to remove all of it and get new w.s. when putting the driver back.
    orangeman
    Neil's H.T. Site
    (plus large selection of H.T.Links and movie images)
  6. Gregg Loewen
    Gregg Loewen Video Standards Instructor, THX Ltd.
    Insider
    Nov 9, 1999
    6,374
    32
    6,610
    New England
    Gregg Loewen
  7. Gary Snyder
    Gary Snyder Auditioning
    Mar 18, 2001
    The secret is removable silicone.
  8. Patrick Sun
    Jun 30, 1999
    38,761
    485
    9,110
    Neil, the WS only has adhesive on one side, the other side is compressed, but doesn't get "sticky", so removing the driver isn't a problem.
    PatCave ; HT Pix ; Gear ; Sunosub I + II + III ; DVDs ; LDs
  9. Hank Frankenberg
    Hank Frankenberg Cinematographer
    Oct 13, 1998
    2,573
    If you use foam weatherstrip, use CLOSED CELL foam, not open cell. The closed cell foam is usually black and the open cell white. Closed cell costs more but works very well. I agree that Mortite (rope putty/caulk) works very well, but is messy when removing a driver later on.
  10. Julian Data
    Oct 5, 1999
    408
    Yes, I forgot to mention that about the foam tape. [​IMG]
    I am actually going to try to get some rubber gaskets made this time. I just need to find a manufactuer to do it. Would this be a grand idea?
  11. Brandon B
    Brandon B Second Unit
    Mar 23, 2001
    263
    Couldn't you just by some rubber sheet and punch the holes for the screws and cut out the rest with an Xacto knife?
    Industrial supply places like McMaster Carr
    http://www.mcmaster.com/
    have tons of different types and thickness of rubber sheet.
    BB
    "Yes, a joke. Come, we will laugh in the car."
  12. Julian Data
    Oct 5, 1999
    408
    Yes, yes.. could do that! [​IMG]
    I am going there now and ordering some.
    TY for the info.
    jd
