What is the best energy compliance display device for 30" plus?
Discussion in 'Displays' started by Tim_, Jun 14, 2005.
  1. Tim_
    Tim_ Stunt Coordinator
    Mar 25, 2005
    95
    What is the best energy compliance display device for 30" plus? Front Projector, Rear Projector, Plasma, LCD, DLP or tube tv.
  2. Arthur S
    Arthur S Cinematographer
    Jul 2, 1999
    2,568
    If you mean energy consumption, plasma is way down there ( in terms of efficiency). I would guess that projectors with a big bulb, i.e., front projectors, DLP, use next most. Surprisingly, my 65 inch CRT RPTV uses only 185 watts. A 65 inch plasma uses 700 watts.
  3. Tim_
    Mar 25, 2005
    95
    I'm looking for something with very low energy comsuption and still help protects the vision of the young ones. My TV is at work anywhere from 6 - 8 hours a day.
  4. Arthur S
    Jul 2, 1999
    2,568
    46 inch Toshiba CRT RPTV 185 watts
    32 inch LCD panel 182 watts
    42 inch LCD Rear Projection 230 watts
    32 inch tube 240 watts
    Plasma 225 watts (37 inch commercial) and up.
  5. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    Are those "typical usage" powers or maximums?
    Over the last 2 months I have seen two references that yes, the maximum power a plasma uses is more than an LCD panel, but in normal usage they are very comparable. The reason why is that a plasma only needs and uses power for the pixels that are lit up at any one time. An LCD must apply power to all of the pixels all the time.
  6. Arthur S
    Jul 2, 1999
    2,568
    Kevin
    I can't answer your question. All I can say is that a lot of plasmas have fan cooling. FWIW here is what Panasonic lists energy consumption as for various sizes in the 7 series:
    37 inch ED: 225 watts
    42 inch ED: 290 watts
    42 inch HD: 357 watts
    50 inch HD: 480 watts
    65 inch HD: 695 watts
