What is SVM?
Discussion in 'Archived Threads 2001-2004' started by Chris PC, Mar 27, 2002.
  1. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    Just wondering what this is? Scan Velocity Modulation? Toshiba only?
    Are there any other "features" of other brands of RP HDTV's that are lame and advisable to disable?
  2. Jesse Skeen
    Jesse Skeen Producer
    Apr 24, 1999
    4,504
    341
    4,110
    Several TVs have this; it's like edge-enhancement applied by the TV- my 40-inch Mitsubishi picture tube came with this and applied a thin outline to the edge of everything onscreen. Very annoying, and made it hard to read onscreen text a lot. I had to go inside the set and unplug something from the board on the end of the tube to disable it, but some sets will let you turn it off electronically. I don't know why they have these on TVs since most people who know about it don't want it!
  3. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    Cool. Thanks. Thankfully it can be defeated though.
  4. Jack Briggs
    Jun 3, 1999
    16,738
    129
    SVM = scan velocity modulation. Bordered images, with one being darker than the other, are scanned more frequently (velocity modulation) so as to give the appearance of sharpness. But it's nothing more than a built-in distortion at the expense of true resolution. Unfortunately, however, the mass-market buyers prefer it.
    With most sets, SVM can only be disabled from the service menu. But more and more sets are offering this option in the user menu (the Sony WEGAs).
    It is nearly always best to defeat SVM.
  5. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    Can I assume that sets I see in the Future Shop like the Sony KP57HW40 and Toshiba 50HX81, Hitachi and Panasonic PT series all probably have SVM enabled? Future Shop is a change of electronics/appliance stores in Canada.
  6. Michael Reuben
    Michael Reuben Studio Mogul
    Feb 12, 1998
    21,763
    3
    5,110
  7. errol
    errol Stunt Coordinator
    Dec 29, 1999
    150
    Hi ya folks,
    Here is a graphic of SVM plus ways to deactivate it.
    Errol
