What is scaling? (1 Viewer)
Alex_C
I'm deciding between the rp82 and rp91. I've read that if my TV doesn't do scaling I should get the rp91, otherwise the rp82.
I have a 65" mits, HD ready.
Help!
Allan Jayne
Scaling is the reformatting of the picture to occupy more or fewer scan lines than it did before. With large screens, the 480 scan lines of DVD are coarse enough to be visible and the picture can be made to look smoother by using more scan lines spaced closer together.
Sometimes you don't have any choice in the matter of scaling or the amount of scaling. Some TV sets, in order to reduce the number of convergence and geometry adjustments, have only one scan rate, for example 1080i HDTV. The TV will have a built in scaler to convert the usual analog video (480i) but not necessarily all of the HDTV formats. Nowadays HDTV sets rely on the HDTV tuner box to scale some of the HDTV formats.
You will have to speak with someone with technical knowledge about your TV to find out whether it scales everything to 1080i.
Scaling needs good processing (formulas; algorithms) and scalers vary widely in quality. I don't have enough experience with different kinds of scalers to tell which are the best. Diagonal lines and edges are a good test of a scaler's quality.
If the TV displays 1080i only and scales all other video inputs to 1080i, some folks ask, why not feed in 1080i from the DVD player and skip the TV scaler? The problem is, DVD is 480p and the DVD player now needs a scaler to convert the video to 1080i. The new question is, who has a better scaler, the DVD player or the TV. I can's answer that last quesiton. (Nowadays very few DVD players have scalers.)
Adjusting the drawing of the scan lines slightly, 480p comes out as 960i with just as good quality as 1080i HDTV and with no scaling. 960p (and 1080p) is better still but you have to pay for that extra quality.
Actually, if you don't absolutely need scaling, no scaling is better. Provided the TV can keep the convergence correct, using (unscaled) 960i for DVD and genuine 720p and 1080i for HDTV as needed is better than scaling everything to 1080i.
More:
http://members.aol.com/ajaynejr/vidscale.htm
Jim A. Banville
I think there is some confusion here. Alex_C needs to know if his TV locks into anamorophic mode when fed 480p. If so, he needs a DVD player that will adjust the geometry of the image of non-anamorphic widescreen DVD's.
ManW_TheUncool
His Own Fool
The BK
ManW
Maybe we need a different approach to this question. :D
Alex,
I suspect you have either Titanic or True Lies on DVD, no?
Play it on your existing player w/ the 65" Mits and watch it at your viewing distance, etc. Assuming you want the picture as big as possible (but still OAR), apply the appropriate TV zoom mode. How does the picture look to you? Are you satisfied w/ it? If not, what looks "wrong" to you? Do you see distracting gaps in the image? Do you see jagged edges that bother you? And so on...
If the PQ looks satisfying enough w/out anything particularly wrong, then you probably don't need a scaling player.
Do you watch lots of foreign films w/ subtitles? Pop in such a DVD and watch it as you normally prefer. Can you see the subtitles? If not, then you'll need a scaling player to handle the subs.
BTW, I notice that you're an attorney and specialize in technology(!). Maybe you can help us start a crusade to make scaling a required feature in the DVD-V player spec, especially in the future HD-DVD spec. :D
_Man_
Sanjay Gupta
Sanjay Gupta
Hmmm, I don't know about Alex_c but I am still a little confused about this whole scaling business. Personally I am more interested in getting an answer to what 'Jim A. Banville' mentions in his post, which is, what all players adjust the image geometry of non anamorphic DVDs for Televisions that lock into anamorphic mode with their 480P inputs. I currently have a Philips 55" 16:9 HD compatible TV (480P & 1080i) which locks into the anamorphic mode when the 480P input is used, luckily for me I also have the Pioneer 755Ai (47Ai in the US) DVD player which has an option in TV type called '16:9 Squeezed', which horizontaly squeezes the picture of non anamprohic DVDs to make up for the vertically squeezed picture on the TV. What I end up with is a picture with correct aspect ratio, albeit with black bars on all four sides.
What I need to know is if and how this is related to the term 'scaling'. Also I would like to know what all equivalent or better players than the Pioneer have this feature, specially does the Denon 2900 have it or not. I am thinking of changing my Pioneer for the Denon 2900 and this feature is of the utmost importance to me.
Sanjay
Member since 1997
ManW_TheUncool
His Own Fool
The BK
ManW
Sanjay,
The Denon 2900 will not do what you want. It has a 4x3 shrink mode that does the same thing as your Pioneer's 16x9 Squeezed mode, but no scaling of a non-16x9 letterbox image.
The kind of scaling Allan described earlier is not exactly what you want. What you want is correct aspect ratio w/ the image filling more of the screen to the point that there are no side bars (like you have w/ the Pioneer's 16x9 Squeezed mode).
For now, the Panny RP91 still seems to be the best player w/ the letterbox scaling capability you want. Maybe one of the upcoming Denon players w/ a Faroudja chip will have it.
Personally, I'm hoping someone will create a firmware hack for the Philips 963sa to enable this feature since it has the Faroudja chip w/ that capability.
_Man_
Sanjay Gupta
Sanjay Gupta
Thanks Man-Fai Wong. If I understood you correctly, then you are saying that the Denon does have a similar feature to what the Pioneer 47Ai has, except that it is called '4x3 shrink mode' instead of what Pioneer calls it, which is '16x9 squeezed mode'. Also that the results in both cases is the same, that is a corrected picture aspect ratio with black bars on all sides.
Also if I understand correctly, then the RP91 uses 'scaling' to correct the aspect ratio, but in this case it does it without putting black bars on the sides.
Sanjay
Member since 1997
Scott Merryfield
Mich. & S. Carolina
Scott Merryfield
For 16x9 TV owners, the RP-91 does scale/reformat a 4x3 image by adding side black bars and retaining the proper 4x3 image within the 16x9 screen. For non-anamorphic widescreen material, the RP-91 also will zoom/scale the 4x3 frame to a similar size as a 16x9 anamorphic transfer (generally performing this function with better image quality than the zoom-only modes on most 16x9 televisions).
The RP-91 performs the above functions automatically for discs that have the appropriate flags to indicate whether they are anamorphic, full frame or non-anamorphic letterboxed. For those titles that are not properly flagged, the RP-91 offers the ability to manually invoke the proper aspect ratio / scaling.
Ernest
JVC 40B and the new Panny S35 have Zooms that re-format letterbox to 16 x 9. It is the same feature that comes standard with Toshiba HD 16 x 9 TV's and they call it "Theater Wide". Toshiba's zoom employes 3 stretch modes that re-formats the incoming signal to 16 x 9.
The S35 uses a pretty good filter so the picture does not become distorted and it allows the user to zoom step by step, or 1:85x1, 16x9, etc. This eliminates over scanning. The JVC also uses a very good filter but their zoom starts at 1.8 which is fine for 2:35 x 1 or larger, but results in over scanining anything for formats less than 2:35 x 1.
If your TV locks in "Full" (I always thought that was a programming bug and we would not see it in newer models) I recommed the S 35, progressive scan, that sells for $99.00 less $20.00 mail in rebate. If the rebate is still active. The player also plays RAM which can come in handy if you own a R/RAM recorder, like the E80.
almico
