What is PCM?
Discussion in 'Archived Threads 2001-2004' started by matthew_rm, Aug 10, 2002.
  1. matthew_rm
    matthew_rm Second Unit
    Dec 24, 2001
    379
    On my Denon 2802 and Sony DVD, I see PCM. WHat is it, and how/why should I play/use it?
    Thanks for any help!:b
  2. RichardMA
    RichardMA Second Unit
    Apr 16, 2002
    446
    From seachnetworking.com:
    PCM (pulse code modulation) is a digital scheme for transmitting analog data. The signals in PCM are binary; that is, there are only two possible states, represented by logic 1 (high) and logic 0 (low). This is true no matter how complex the analog waveform happens to be. Using PCM, it is possible to digitize all forms of analog data, including full-motion video, voices, music, telemetry, and virtual reality (VR).
    To obtain PCM from an analog waveform at the source (transmitter end) of a communications circuit, the analog signal amplitude is sampled (measured) at regular time intervals. The sampling rate, or number of samples per second, is several times the maximum frequency of the analog waveform in cycles per second or hertz. The instantaneous amplitude of the analog signal at each sampling is rounded off to the nearest of several specific, predetermined levels. This process is called quantization. The number of levels is always a power of 2 -- for example, 8, 16, 32, or 64. These numbers can be represented by three, four, five, or six binary digits (bits) respectively. The output of a pulse code modulator is thus a series of binary numbers, each represented by some power of 2 bits.
    At the destination (receiver end) of the communications circuit, a pulse code demodulator converts the binary numbers back into pulses having the same quantum levels as those in the modulator. These pulses are further processed to restore the original analog waveform.
  3. Jagan Seshadri
    Jagan Seshadri Supporting Actor
    Nov 5, 2001
    528
    Some older receivers don't accept Dolby Digital or DTS signals coming from a DVD player, so DVD players provide the option of sending PCM Stereo instead, which has been used since the CD era began and therefore is usually accepted by older receivers.
    Only switch to PCM if Dolby Digital and DTS signals aren't working with your receiver.
    -JNS
  4. Sihan Goi
    Sihan Goi Second Unit
    Nov 2, 2001
    442
    That's not entirely true, remember there's also a 24bit format? Also, 18bit and 20bit DACs do exist too. In fact, if one really wants to, one can have levels that are odd number too, but its not intuitive and hence not used.
