What is PAL/NTSC?
Discussion in 'Archived Threads 2001-2004' started by Marshall Alsup, Mar 3, 2002.
  1. Marshall Alsup
    Marshall Alsup Second Unit
    Jul 9, 2001
    497
    what is PAL/NTSC. What do these acronyms stand for, and what's the difference?
    Thanks guys
    Marshall
  2. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    NTSC is the video format used in the USA and a few other places (Japan and Mexico are both NTSC also I believe). It is a specific frame rate and resolution- it is basically the format you know as video (29.97 frames per second, interlaced 60 fields, 480 lines).
    PAL is the format used in Europe and other areas. Their video format is different than the US format, it consists of 576 lines and is 25 frames per second.
    There is also a third format, SECAM that is used in some countries.
    These differing systems make it impossible to watch European video sources on USA TVs- the video format itself, regardless of what the carrier (DVD, VHS, etc)- is simply a different frame rate and resolution than out TV monitors are designed to work with.
    I believe that NTSC stands for Nation Television Standards Commission (or Committee)- named after the organization who developed the standard at the advent of television broadcasts... the same way SMPTE time code is named after the group that developed it (Society of Motion Picture and Television Engineers).
    Some people joke that NTSC stands for "Never Twice the Same Color".
    I'm not sure where the distinction "PAL" originated- think it has something to do with 'P***** alternating lines'.
    Here's some info in case you want all the specifics:
    http://www.michaeldvd.com.au/Article.../PALvsNTSC.asp
    http://www.alom.com/services/allstandards.html (country list of who uses what)
  3. Marshall Alsup
    Jul 9, 2001
    497
    Thanks Vince, You rule!
  4. Brian E
    Brian E Screenwriter
    Aug 12, 2000
    1,636
    Basically they are the different formats TV's use in various parts of the country.
    N T S C
    National Television System Committee
    Lines/Field 525/60
    Horizontal Frequency 15.734 kHz
    Vertical Frequency 60 Hz
    Color Subcarrier Frequency 3.579545 MHz
    Video Bandwidth 4.2 MHz
    Sound Carrier 4.5 MHz
    TV's in the US, Japan, Canada, etc. use this.
    P A L
    Phase Alternating Line
    PAL
    Line/Field 625/50
    Horizontal Freq. 15.625 kHz
    Vertical Freq. 50 Hz
    Color Sub Carrier 4.433618 MHz
    Video Bandwidth 5.0 MHz
    Sound Carrier 5.5 MHz
    PAL N
    Line/Field 625/50
    Color Sub Carrier 3.582056 MHz
    PAL M
    Line/Field 525/60
    Horizontal Freq. 15.750 kHz
    Vertical Freq. 60 Hz
    Color Sub Carrier 3.575611 MHz
    TV's in Europe, United Kingdom, S. America, Australia Etc. use this.
    SECAM
    Sequential Couleur Avec Memoire or Sequential Color with Memory
    SECAM B,G,H
    Line/Field 625/50
    Horizontal Frequency 15.625 kHz
    Vertical Frequency 50 Hz
    SECAM D,K,K1,L
    Line/Field 625/50
    Video Bandwidth 6.0 MHz
    Sound Carrier 6.5 MHz
    Used in France and I believe part of E. Europe.
  5. Vince Maskeeper
    Jan 18, 1999
    6,499
  6. Brian E
    Aug 12, 2000
    1,636
