What is comb filter and why are mine out of allignment?
Discussion in 'Archived Threads 2001-2004' started by Jeff Rul, Nov 26, 2001.
  1. Jeff Rul
    Jeff Rul Auditioning
    Nov 20, 2001
    2
    I recently bought a Samsung TSl3294 HDTV ready TV. It worked for about an hour and then the colors went out of wack. First it dropped colors and it finally ended up looking like an old 8-bit image from the early days of the Internet. Finally the audio dropped out.
    A friend says its the comb filters. Is there any way to adjust them?
  2. Bill Slack
    Bill Slack Supporting Actor
    Mar 16, 1999
    837
    A comb filter seperates chroma (color) and luma (b+w) signals on composite sources. If the source is being fed via S-Video or Component, than the comb filter shouldn't even be active.
  3. Jeff Rul
    Nov 20, 2001
    2
    Maybe its not the comb filter, its happening with video sources from cable/co-ax, S-Video and composite.
    One of the first symptoms was bright white saturated highlights turning black. Such as reflections on people's faces.
    Any ideas I'm going to return the TV soon if it can't be fixed.
  4. Bill Slack
    Mar 16, 1999
    837
    If you can exchange it, just do that.
    Never heard of anything quite like this before. Good luck!
