What is best way to clean optical terminals (1 Viewer)
Gerard Martin
Experiencing audio dropouts believe due
to dust/dirt, have no problem with Coax
input so receiver DVD player OK. TIA.
Chu Gai
You might consider visiting your local camera store and obtaining cleaning fluid that's used for lenses. There are also lintless type 'q-tip' products that'll help you get into tight spaces. Then follow it up with a blast of compressed air. I take it you've confirmed the cable is not at fault.
Ted Lee
i use some q-tippy type stuff i got (i think) from rat-shack. it doesn't have cotten at the end...it's more like a spongy material. it has an extra long handle so it's pretty versatile.
i also think a good blast of canned-air should do the trick.
btw - i've been using the optical connections on my md from day one, but i've never cleaned them. i wonder if something else (maybe like chu said...the cable) is really the problem.
John Royster
Recommended cleaning for fiber optic ends is isopropyl alcohol and lint free cloth. This is for communications fiber optics, so I guess the same could apply for consumer based TosLink stuff.
Righ
