What is best for basement HT floor? (1 Viewer)
Dan_J_H.
I am planning to build a HT in my basement. The size will be 12'-10" by 25'. I have a tiled cement floor. I have heard that a carpeted wood floor is better than a carpeted tile floor. Is a wood floor really better? If so, what is a good way to construct the floor? My celiling height is 7'. I do have a drain in the middle of the floor, so there is a slope to the drain.
Dan
Massimo N
I'm using a product called DRICORE ... I'm actually installing it today :) It looks like a fairly simple process.
DRICORE comes in 2'x2' sheets of pressboard with a plastic backing with some nubs to raise it off the floor. It's supposed to keep the floor dryer, warmer etc. I also wanted it to transfer the bass through the floor.
You can read more about the product here:
DRICORE Home Page
In Canada, you can buy the flooring @ HomeDepot, so I'm going to assume the same in the States.
I had a friend install this product in his basement about a year ago, where his concrete floor was very un-even. The leveling kits did not provide enough leveling. They needed to install sheets of pressboard ontop of the product which did a great job.
Hope this helped.
Cheers,
Mass
MBH
