What is acceptable hiss comming from receiver?
Discussion in 'Archived Threads 2001-2004' started by MattSherlock, Mar 10, 2002.
  1. MattSherlock
    MattSherlock Stunt Coordinator
    Aug 4, 2001
    83
    I have a Denon 3802 and I was wondering how much if any hiss I should be hearing from my speakers. I do hear a faint hiss from my mains which are Klipsch KLF 10's when I have the volume maxed out. I like some feed back from others out there if you put you receiver in direct mode and change to an input you don't use and max out you volume. Do most hear absolute silence
    or some hiss at all, just curious.
  2. Chris Demaree
    Chris Demaree Stunt Coordinator
    Nov 3, 2000
    108
    With my Outlaw 1050, I could only hear hiss when the volume was almost at the maximum. At normal listening levels, it was dead quiet. To me, it's only a problem if you can hear 'noise' during the quietest scenes in movies or passages in music (like between two tracks on a CD).
  3. Chriss M
    Chriss M Second Unit
    Dec 14, 2001
    320
    are we talking about from the listening postion, or with your ear up against the tweeeter?
  4. Kevin. W
    Kevin. W Screenwriter
    Oct 27, 1999
    1,534
    With my Marantz AV560U/Rotel RMB-1066 combo I get ZERO hiss with the volume at max and my ear at the speakers.
    Kevin
  5. ScottH
    ScottH Producer
    Jan 2, 2001
    3,196
    117
    4,110
    Scott Hanson
  6. Paul Clarke
    Paul Clarke Supporting Actor
    Jan 29, 2002
    998
    And of course speaker wire has an influence as well, both length and quality.
  7. Earl Simpson
    Earl Simpson Supporting Actor
    Jan 12, 2002
    803
    I probably couldn't hear it anyway. But another 3802 owner called Denon and R&R his unit. But his was a loud hiss. See 3802 defects post.
    I will check it now! Wish me luck!
    Yes! At +++++14 max volume I can hear the ocean. This is normal for any amp. Not a hiss but background noise.
    I used the phono input which is double amplified!
    I will try to find another input that is empty!
    ------- 19 is as loud as I play anything.
    OK// aux tape is 75% less back ground noise than phono at + 14. And no, I will not do this with any used input. This is all normal for a high output RCVR. It is pumpimg 110 RMS over 20-20000 cycles. I think that is great for background noise. You will never hear this playing any kind of signal. Now , if you hear a hiss with music, send it back. The sig level should be 100 times any circuit noise with real signal volts flowing through the circuits.
  8. Kevin. W
    Oct 27, 1999
    1,534
  9. Ron Reda
    Ron Reda Cinematographer
    Jul 27, 2001
    2,276
    2
    110
    On my CD input, I only hear very faint hissing when my ear is at the speaker, but like someone said previously, that is normal for tweeters. Now, any input that involves my TV produces a hum, but that's a whole different story altogether!
