What is a Mud Ring?
Discussion in 'Archived Threads 2001-2004' started by Greg_L_C, Jul 16, 2002.
  1. Greg_L_C
    Greg_L_C Stunt Coordinator
    Mar 9, 2002
    126
    I am doing some reading on cable installing and found several references to Mud Rings. I think I got an idea of what they are and way you would want to use them, but I've never seen them. Could someone maybe explain the purpose of using Mud Rings and where I might find them for purchase?
    Greg
  2. Bill_D
    Bill_D Supporting Actor
    Dec 10, 2001
    755
    A mud-ring is a raw electrical wallplate used for low-voltage application. Low-voltage applications don't require an enclosed box per building code so they are normally just an empty wall box frame.
  3. Jeff Mills
    Jeff Mills Stunt Coordinator
    Feb 8, 2002
    95
    I thought mud rings wire for sticking your cable into....pun intended!
  4. Blake R
    Blake R Stunt Coordinator
    Feb 26, 2002
    77
    A mud ring is also an extension ring which is screwed onto another outlet box usually during the rough-in. If you were going to install, say, a fire alarm strobe in a wall that was going to be tiled you would add an appropriate depth mud ring during the rough-in and "blank" it off.
