what is a monitor out?
Discussion in 'Archived Threads 2001-2004' started by ChuckM, Jan 17, 2003.
  1. ChuckM
    ChuckM Stunt Coordinator
    Aug 12, 2002
    149
    On the recievers what is the purpose of the monitor out, and what is the diffrence between it and the dvd out.
  2. ColinM
    ColinM Cinematographer
    Dec 9, 2001
    2,050
    "Monitor Out" goes to the display (TV).
    A monitor is a TV without a tuner, or, your TV on it's Video input.
    Is the same jack labeled DVD Out?
  3. ChuckM
    Aug 12, 2002
    149
    Also on the Onkyo ht-s650 can use the 6 channel inputs for dvd-audio player while using the dvd video in and optical in for my dvd player. Last question how do you associate the video ins with the optical/coaxial ins.
  4. ChuckM
    Aug 12, 2002
    149
    Ok, say i have a device on video 1, video 2, and dvd. Can I see all three, not at the same time of course, through the monitor out.
  5. ColinM
    Dec 9, 2001
    2,050
    Yes - -I think -
    All video sources go into the Onk, and the Monitor Out to the Video In on your Tee Wee set.
    When you switch sources with the Onk, the corresponding video will display.
    When in a source, you may select the digital audio in to go with it, at least with my HK you can. Hitting the digital button on the remote cycles through them all, including the associated analog in. Leave it where you want it and you're golden.
    Good luck
  6. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    "Monitor out" is a confusing term.
    Sometimes the "monitor out" is supposed to go to the TV.
    Sometimes you use "monitor out" to go to the VCR to record from and "video out" to go to the TV.
    Sometimes the composite output jack is called "monitor out" and/or the component output jack cluster is labeled "DVD out" while the S-video jack is still labeled "S-video out".
    You will just have to check your A/V receiver (or HTiB main unit) instructions.
    Video hints:
