What is a good 5.1 or 6.1 set up for $1500 (1 Viewer)
Richard Gray
If you had a decent Receiver such as the Yamaha RX-V1200 and a couple of JBL-ND310's for the A mains, what would be a good compliment for them? I like a 60/40 mix of movies (action to drama to Sci-Fi) to music Classics Rock, R&B, a bit of Jazz and even Classical.
2 more JBL Northridge 310's
2 S36II's
2 S-38's
2 S-26's
or N-24's
Also, if I could go outside of the family, so to speak and get another make/manufacturer what would be a good set up?
Duane R
Richard,
I run a Yamaha 2200 (upgraded from a 1200) with 4 ND310's for mains and surrounds. I run about 70/30 music/ht and I was quite pleased with everything. A few days ago, I wired up a Parasound 855 amp and now it sings! I went the 4 tower route because I knew I'd be listening to music as much or more than watching DVD's. Those towers just seem to be more "filling" to me when listening to music. I'd go the 4 tower route again give the choice. Just my .02 ...
Jeffrey Forner
Here are my suggestions, outside of the JBL line:
SPEAKERS
  • nOrh 4.0 Ceramic Loudspeakers ($850)
  • Home Theater Direct Level III speakers (but not their sub)
  • Diva 4.1 surround sound set (includes a pair of 4.1s, 2.1s and C3 center channel) ~$1198 + shipping
I would only recommend the Divas if you did not want to get a subwoofer. If you're interested in a sub, these may be the best choices for you:
SUBWOOFERS
  • SVS 25-31PCi ($549 + shipping) or 20-39PCi ($649 + shipping)
  • Adire Audio Dharman $599 + shipping)
  • Hsu VTF-2 $499
You may mix and match to suit your needs. Hope that helps.
Richard Gray
Thanks Duane,
The 4 tower method seems to be where things will go. As these ND-310's are breaking in nicely. One thing that I didn't expect. The mid to lower bass is very prominent. A little tweaking in the 1200 brought things back.
Jeffrey,
Thanks for the post. I'm still on the fence as far as mixing with other manufactueres speakers. I did get to listen to some other manufactures mid-fi offerings. The Mirage FRX-5 (Tower) and FRX-2 (Bookshelf) and they sound very neutral. That might work out given their neutrality, but the 5's cost more than the ND-310's.
And the Diva 4.1 are very fine setup's. I will give them another listen. With a nice upper mid range sound.
And Yes I am looking for a GOOD thumping, er, Subwoofer. Any suggestions?
Thanks all.
zoobird
