what is a band equalizer?
Discussion in 'Archived Threads 2001-2004' started by felix_suwarno, Feb 18, 2002.
  1. felix_suwarno
    felix_suwarno Screenwriter
    Dec 2, 2001
    1,523
    is it absolutely necessary for a nice ht?
  2. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    I'll take the simple one...[​IMG]
    No, you dont need an equalizer and most HT systems dont have one.
    The exception is that some rooms have poor dimensions for acoustics. Having similar-sized walls will reflect the same frequencies and give you a 4-fold increase in some sounds. This is usually a problem with subwoofers resulting in a very painful "BOOM" at some frequencies.
    So a equalizer is sometimes used to tame these sounds. A very popular device is the Behring Feedback Destroyer. Despite it's name, it is a programmable equalizer.
    There are 2 kinds of equalizers: bandpass and parametric. The BFD is a parametric, and I'll be darned if I can remember the difference.
  3. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
  4. felix_suwarno
    Dec 2, 2001
    1,523
    thanks
