What influences sound more, my pre pro or my amp?
Discussion in 'AV Receivers' started by Chip E, Apr 20, 2004.
  1. Chip E
    Chip E Screenwriter
    Nov 25, 2000
    1,165
    I run a Ref50 pre, a Ref200.5, Ref200.2 amps. Does the pre pro influence the sound more or, is it the amp? Reason i ask is... thinking about changing my pre (eventually). If i bought an Integra pre for example, would the sound change or is it mostly in the amp?
    I'm curious to see some comments. Thanks.
  2. David Judah
    David Judah Screenwriter
    Feb 11, 1999
    1,479
    1.Room/Speakers
    2.Pre-amp
    3.Amp
    Of course, every component in the chain can have an effect, but that's the simple order, IMO. Obviously, the source component will have an effect too, but it depends on the configuration(analog or digital).
    Are you unhappy with the B&K's performance or are there features the Integra has that the B&K lacks?
    DJ
  3. Thomas Tur
    Thomas Tur Stunt Coordinator
    May 13, 2003
    130
    I would agree with David. First the Room, then the pre-amp, then the amplifier.
  4. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    Yes, room & speakers first. I agree too.
    If you're looking for an excuse for another pre/pro, also look at any features you might gain. [​IMG]
    If you're looking at the Integra vs the B&K, I personally think that's more of a sideways trade. (Although a buddy of mine really likes the two channel sound from the Integra.) Now, if you're looking at Integra Research... [​IMG]
  5. Chip E
    Chip E Screenwriter
    Nov 25, 2000
    1,165
    I was using Integra as an example because i used to have an Integra 6.2 receiver, then a B&K 307. The Integra was bright to my ears. There was a big difference. So, i guess changing out my pre would yield a bigger change.. I have no intention of changing my amps. Thanks.
  6. JasonBrandon
    JasonBrandon Agent
    Feb 23, 2004
    46
    amps
  7. Mike SJ
    Mike SJ Supporting Actor
    Nov 10, 2003
    718
