What!? In THX Select modes, sub only used to 35 Hz.!?
Discussion in 'Speakers & Subwoofers' started by Kenneth Harden, Jul 22, 2005.
  1. Kenneth Harden
    Kenneth Harden Screenwriter
    May 13, 2002
    1,365
  2. ColinM
    ColinM Cinematographer
    Dec 9, 2001
    2,050
    Maybe because room gain adds below 35 (200Cu ft vs 3000), and to curb amp clipping on deep bass?
  3. Arthur S
    Arthur S Cinematographer
    Jul 2, 1999
    2,568
    Yep, Select calls only for the subwoofer to extend to 35 Hz. This simply means that for a manufacturer to get THX Select certification for a subwoofer, it must only go down to 35 Hz. This does not apply to the receiver or any other part of the system. The receiver will deliver the full bass signal but the subwoofer doesn't have to deliver below 35Hz.
    Anyone with different info, please chime in.
    Note that Ultra 2 certification requires that the subwoofer deliver down to 20Hz. Again, this applies to subwoofers seeking THX certification.
  4. JeremyErwin
    JeremyErwin Producer
    Feb 11, 2001
    3,218
    2
    Hmm. Seems that the THX subwoofer spec has been leaked
    I recall reading an audioholics article which implied that the Ultra2 spec was very hard to meet.
  5. Gregg Loewen
    Gregg Loewen Video Standards Instructor, THX Ltd.
    Insider
    Nov 9, 1999
    6,374
    32
    6,610
    New England
    Gregg Loewen
    hi guys
    Ultra2 spec is flat down to 20 without room gain.
  6. FeisalK
    FeisalK Screenwriter
    May 1, 2003
    1,245
    I don't understand why THX is secretive about the certification requirements - surely if everyone knew that you'd have to have so and so specs to meet THX Select 2 or watever it would make it easier for consumers?
    unless of course it meant people would see that the cert is meaningless - e.g. why is the fact that the subwoofer is capable of going down to 35Hz part of the receiver certification test?
    the sub is an active sub with its own amp, and the receiver puts out whatever freq (below its xover) that is present in the LFE channel. whether a sub can do 35Hz -3dB is not dependent on the receiver, is it?
  7. PaulDA
    PaulDA Cinematographer
    Feb 9, 2004
    2,696
    96
    St. Hubert, Quebec, Canada
    Paul
    Speakers and subs can get independent ratings for THX, so that's probably why they have various specs for various levels of THX (Select, Ultra, etc).
    THX is superfluous for most people, I suspect. My receiver is THX Select rated, but the only advantage it gives me is knowing the test tones are calibrated to be 75dB on my SPL meter when the volume reads 0dB on the faceplate. Takes the guesswork out of setting my channels (not that I couldn't do it without this feature). Unless I had THX speakers that matched the xover slope requirements of THX, then the rest is meaningless to me. I experimented with using THX on DVD soundtracks and found it useless on most things, and detrimental on a few concert DVDs, so I never engage THX processing.
