What if I connect my Klipsch RF-7s to an HTiB's receiver?
Discussion in 'Archived Threads 2001-2004' started by Haris Ellahi, Mar 4, 2003.
  1. Haris Ellahi
    Haris Ellahi Second Unit
    Oct 30, 2001
    485
    110
    When we bought our plasma, we got a free Panasonic home theater (one of those all-in-one home theaters). Since we still don't have our amplifier yet, will it be possible to connect the Klipsch RF-7s to the Panasonic amplifier without damaging the Klipsch? Those Panasonic speakers are 6 ohm speakers.
    Click here for more info on that Panasonic amplifier:
    http://www.prodcat.panasonic.com/sho...ategoryId=2607
  2. James Edward
    James Edward Supporting Actor
    May 1, 2000
    855
    You won't damage them if you don't play the system too loudly. As you may have seen from some other posts in this section, it is low powered receivers and amps that have the most potential to damage speakers, strange as it may seem.
    When the amp runs out of steam and clips, it sends distorted waveforms to the speakers; it is those waveforms that damage voicecoils. So keep the volume at moderate levels and the speakers should be fine.
    But who wants moderate levels? Go get that new amp!
    One concern: Without seeing the owner's manual, I can't tell if this is one of those systems like Bose that sends the speaker outputs through the sub to be filtered, and then on to the speakers. If that is the case, you should post that and get some hookup suggestions.
  3. Haris Ellahi
    Oct 30, 2001
    485
    110
    No, the speakers are hooked up directly to the amplifier, not the subwoofer.
  4. James Edward
    May 1, 2000
    855
    Then just hook them up as the other speakers are. I just read a review stating that the Klipsch RF-7s have a sensitivity of 102 db's per watt of input. That is astonishingly high. So they need very little power to play loud.
    But since you have a flagship speaker, you should look for a good sounding receiver to complement it. I suspect
    that you could do better than the Panasonic.
  5. Juan_R
    Juan_R Supporting Actor
    Sep 4, 2001
    683
  6. Haris Ellahi
    Oct 30, 2001
    485
    110
    I will be getting a Parasound HCA-2205A amplifier.
