Bill Bradstreet
- Jan 7, 2001
I'm starting to talk to the company that does the wiring for the builders who are building the house I'm buying (breath). They say they use 14-gauge wire for in the walls.
If I was going to do this myself I was planning on 12-gauge. I think someone else suggested 12-gauge in an earlier thread.
Should I press them to do 12-gauge or will 14-gauge be just as good?
The room is 22x14. The wires are going to spread out from one of the rear corners of the room. Also, do I need to worry about different wires being different lengths? Should I make sure they make left/right pairs the same length? Will that matter for a room this size?
