What gage speaker wire?
Discussion in 'Archived Threads 2001-2004' started by Matt Lando, Dec 2, 2001.
  1. Matt Lando
    Matt Lando Agent
    Dec 1, 2001
    25
    What gage speaker wire should be used with a receiver that puts out either 80 or 100 watts per channel and bookshelf speakers that can handle 100-150 watts?
    Is 16 gage enough? Does 12 gage make any difference? How does the gage of the wire effect performance? Thanks.
  2. RichardH
    RichardH Supporting Actor
    Nov 28, 2000
    742
    Wire gauge has to do more with how long of a run you're going to have than the speakers or receiver themselves. For anything less than 15ft. runs, 14ga should be fine. If you're doing like 20ft. or longer, you could step up to 12ga.
    The thicker the wire, the less resistance it has on the signal. But, we're talking tiny fractions of an Ohm, so even a relatively long run of 16ga will not have enough resistance to affect the signal.
  3. Howard_S
    Howard_S Supporting Actor
    Nov 1, 2001
    548
    So the smaller the gauge the better and more expensive?
  4. Nick G
    Nick G Stunt Coordinator
    Aug 12, 2001
    152
    Matt here is link to a site that has a table which shows amoung other things what guage you need for various run lengths. The table is very near the begining, so need to scroll down just a bit to find it.
    Regards, Nick
    http://www.sundial.net/~rogerr/wire.htm
