John-Miles
- Nov 29, 2001
I am curious for things like component video switching, what frequency is required?
I am curious for things like component video switching, what frequency is required?As Doug said, it depends on what's being carried. Component video is usually used for 480i (standard NTSC), 480p (prog-scan DVD or "SDTV), or 1080i (HDTV).
Are you considering a certain receiver or pre-pro and wondering if it would do a decent job with carrying a certain component signal?
It would all depend on the type of display, the type of signal, and the actual performance of the receiver or pre-pro. The owners of individual models of HT gear would probably be happy to give you feedback on the kind of performance they get with the various types of signals.
However, there's an inexpensive way to insure the best possible video connection: connect your source device directly to the display. Many displays on the market have multiple high-rez component-video inputs, so you can use the display to switch between DVD player, STB, or whatever source you want to connect (higher-end TV's usually have several standard composite-video inputs and you can use those for your NTSC sources such as a standard cable box or a VHS VCR).
