What exactly is a "transport"?
Discussion in 'Archived Threads 2001-2004' started by Antonio, Apr 5, 2002.
  1. Antonio
    Antonio Extra
    Mar 16, 2002
    22
    I have comes across this term while reading through posts in on the forum. Can anyone define it?
  2. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    The term "Transport" means the box/device that mechanically holds the CD/DVD.
    High-end music systems often have a very strong, rigid, heavy "transport" for a CD player. A optical connection then takes the raw bits to a external box called a "pre-processor" that converts it to analog audio. Then this signal is usually passed to an external amplifier, then to the speakers.
  3. RobertCharlotte
    RobertCharlotte Supporting Actor
    Feb 21, 2002
    660
    Hmmm. I think I've been misunderstanding, then. Just to be sure, tell me if I'm understanding you right: the transport is not just the moving parts of the CD player (or DVD player or whatever), but the entire unit itself?
  4. Jeff Kleist
    Dec 4, 1999
    11,267
    The transport is the physical mechanism that takes the disc and sucks it into the machine, and then holds it in place while it plays
  5. RobertCharlotte
    Feb 21, 2002
    660
    Okay, that's what I thought. I think. [​IMG]
  6. Selden Ball
    Selden Ball Second Unit
    Mar 1, 2001
    412
    Selden
    The term "transport" is used with both meanings:
    + it's used to designate the part of the cd/dvd player that spins the disc
    + and it's used to mean the player itself when its analog audio circuits aren't used. When the digital audio is decoded externally, people often say the player is being used as a transport.
    The latter actually isn't quite right, of course. A lot of digital processing goes on in a player before it can provide the serial digital audio signal in a format that external decoders can handle.
