What does DVD rot look like?
Discussion in 'Archived Threads 2001-2004' started by chris larralde, Oct 24, 2002.
  1. chris larralde
    chris larralde Stunt Coordinator
    Jan 14, 2001
    187
    I think I may have some on a number of my disks [​IMG]
    It looks clouded in areas.
  2. Jeff Kleist
    Dec 4, 1999
    11,267
    clouding doesn't mean anything, it's just a sign of how the glue cured. There is no such thing as DVD-rot, only defective discs that were improperly sealed. If the disc still plays fine, you're fine.
    Laser Rot was a common occurance with LDs for a variety of reasons, a big one being the size of the discs caused them to flex a great amount which would break the seal and allow oxygen in
  3. BrianP
    BrianP Supporting Actor
    Dec 8, 1999
    601
    Have you tried playing the discs to see if there are any problems of freezing or pixelation, especially after a layer change? I have read many threads that noted a problem similar to what you describe but the discs played fine.
  4. MikeM
    MikeM Screenwriter
    Nov 23, 1999
    1,203
    It looks a very similar to Wonder Woman's airplane. [​IMG]
    Seriously though, Jeff hit it right on the money. There may be glue related issued on earlier discs, but there's really been no clear cut case of dvd rot a la LDs.
  5. Andrew Chong
    Andrew Chong Supporting Actor
    May 7, 2002
    739
  6. Jeff Kleist
    Dec 4, 1999
    11,267
    Like I said, the cloudyness means nothing.
