what do you think of " DDR-SDRAM" ?
Discussion in 'Archived Threads 2001-2004' started by Eric Stuckey, Feb 2, 2002.
  1. Eric Stuckey
    Eric Stuckey Second Unit
    Mar 24, 1999
    421
    My new Dell has this.Is it fast?
  2. Eric Alderson
    Eric Alderson Stunt Coordinator
    Apr 22, 1999
    249
    Yes. And you got a DELL dude!! [​IMG]
  3. Nick_Murphy
    Nick_Murphy Agent
    Dec 17, 2001
    27
    Put it this way, DDR = "Double Data Rate". So if you're used the the standard SDRAM, all this is, is double clocked SDRAM, so 128 DDR = 256 SDRAM...........yay!!!
  4. Matt Stone
    Matt Stone Lead Actor
    Jun 21, 2000
    9,063
    It doesn't quite do that. It doesn't double the "size" of the RAM, it doubles the "speed". But, hell...it doesn't really fully double that either, it's just faster. An example is the fact that SDRAM stands for Synchronous Dynamic Random Access Memory...the point is the clock speed of the ram is synched up with teh clock speed of the processor's Front Side Bus. Regardless of all that jargon, yes...DDR is better because it's faster than regular SDRAM.
  5. Kelley_B
    Kelley_B Cinematographer
    Feb 27, 2001
    2,324
    DDR can write/read on both the upside and the downside of the clock cycle. Therefore it theoretically doubles the clock speed of the RAM, 133=266, 100=200, etc...
  6. Chris Tsutsui
    Chris Tsutsui Screenwriter
    Feb 1, 2002
    1,865
    You'll notice a difference if upgrading from SDRAM to DDR if your Dell is a Pentium4. But then again unless you use games and applications that use high memory bandwidths, you probably couldn't tell.
    Another reminder is that RDRAM has better performance than DDR memory so you almost have the best. [​IMG]
    If you can't get your RDRAM up to PC1066 level (133Mhz x 4), you can always change the multiplier.
  7. AndyVX
    AndyVX Supporting Actor
    Aug 2, 2000
    804
    But RDRAM has horrible latency.
    Intel isn't switching to DDR just because of the cost difference to the consumer you know.
  8. Eric Stuckey
    Mar 24, 1999
    421
    It is a P-4 with 256 ram w/40 gb hard drive. I wont be playing games on it. I just wanted something that would last me a few years and if maybee later i wanted to get into games or what ever else, i can. Dell beat Gateway on every level, price,feature's, and as soon as I said "gateway" Dell offered me free stuff.
