What do you think of a Universal Battery for Portable DVD Players?
Discussion in 'Home Theater Projects' started by DanielKellmii, Apr 28, 2006.
  1. DanielKellmii
    DanielKellmii Supporting Actor
    Feb 5, 2004
    524
  2. DanielKellmii
    Feb 5, 2004
    524
    Anybody ever use a similar produce?
  3. Jim Rakowiecki
    Jim Rakowiecki Stunt Coordinator
    Sep 2, 2003
    162
    I've never used one but it seems like a good idea. You may want to investigate other options. I did a search on external batteries on Google and found lots of stuff.
    http://www.global-batteries.com/inde...FVCWJAodtApAZw
    http://www.batterygeek.net/
    http://www.batterymart.com/battery.mv?p=LAP-POWERBASE
    http://www.batteryspace.com/index.as...S&Category=521
    Just make sure the voltage is correct and get the highest mah hour rating you can to extend the run time and you should be good to go.
    You may also want to check with the airline and see if the plane has 12v power available at your seat for laptops. An adapter may be cheaper than a battery.
    Good luck.
    Jim
