What do most of these receivers and pre/pros do with a 5.1 signal..
Discussion in 'Archived Threads 2001-2004' started by John Cain, Dec 12, 2001.
  1. John Cain
    John Cain Second Unit
    Nov 19, 2000
    359
    What do most of these pre/pros and receivers that allow for 7 speakers do with the rear two speakers with a DD or DTS 5.1 signal??
    Do they manufacture a false rear channel signal, or do those speakers sit silent??
    -- John
  2. Dan Hitchman
    Dan Hitchman Cinematographer
    Jun 11, 1999
    2,713
    Depends on the mode you put them in.
    If you leave 6.1 decoding on then they will decode the in-phase surround channel material on any 5.1 track (DTS or DD) and route it to the center back speakers.
    Some components allow you to just duplicate the left and right side channels in the center back left and right speakers when 6.1 decoding is left off.
    Dan
  3. John Cain
    Nov 19, 2000
    359
    Thanks Dan..
    -- John
  4. Drew Eckhardt
    Drew Eckhardt Stunt Coordinator
    May 10, 2001
    246
    Lexicons operating in 5.1 or DTS Logic-7 mode generate a stereo signal appropriate for the situation at hand.
    Pans which would normally go from front speakers to the surrounds seem to pass by the side surrounds and end at the rears, while persistant ambient noise comes from all four surround speakers, and THX-EX encoded surround back comes from the rear pair.
